CMbuildz bolt on intercooler feeler
Trader history for CMbuildz Racing (0)
simi valley
Sup guys so been throwing around the idea of a low budget good quality bolt on intercooler set up for the fiesta st platform. I'm going to be utilizing a Godspeed Type C intercooler. All the info about the intercooler will be listed below. I just got my core in today and will start posting pic on the install and what's included...I believe this will be a great addition for this platform, size is perfect, bar and plate core design and it's capable of more then enough HP then most ST guys are making as a daily driver. Lmk what you guys think. Great to be back
TYPE-C INTERCOOLER??max horsepower capacity : 200-450HP?*
core length
24"
core height
7.5"
core thickness
3"
inlet / outlet size
2.75"
end to end length
30"
compress air flow rate
700cubic feet/min,400hp max
working pressure
35-40 psi
pressure drop
0.2-0.5@15psi,2-5psi@35psi
material
100% aluminum
design
bar and plate=high flow
construction
machine cut & stamped, hand welded
finish
polished
net weight
16 lbs
CMbuildz Racing
simi valley
Update 3/11/17
Intercooler prototype bracket made and intercooler is welded and mounted... let me know what you guys think
Charles Town
I was already having a hard enough time deciding what intercooler to go with... and then you guys just have to go and do this! [?|] haha
Denver
When are you expecting to release this and at what price? Possible group buy for the first batch?
Sent from my SM-G935V using Tapatalk
re-rx7
Ardmore
looks quite a bit larger than the cobb unit. You build it and I will buy i an give a review vs the cobb with cars setup. In the market for a new IC
CMbuildz Racing
simi valley
That looks pretty good!
Thanks for all the input guys ... I've had this one my car now for a day 1 day. So far it performs just as well as any other intercooler on the market. Sits right at 5-10 degrees above ambient. I'm just testing at the moment. Have to make sure bracketry can withstand be daily driven without abnormal rattles and what not.
My J line bracketry was a success so I would want the same for this product as well. As far as a release date? I'm really not sure. I'm kinda moving more toward adding my own aluminum bungs so that I could just use my current J line bracketry design as appose to having to manufacture a whole different bracket that's only specific to the type C core.
That would lower my cost and also I would be able to provide this set up for a affordable price as promised. Thx for the interest and stay tuned for more updates
Pomona
Any word on this intercooler? I see an ad on cl and this guy is selling his red st. did he not make these intercoolers or what
