COBB cracks FoRS ECU and Begins Stage 1 Tuning...
Great info in video and also tips on how to correctly dyno RS AWD!
Baseline numbers and a Stage1 pull.
"On the dyno with our Ford Focus RS. Baseline numbers and a Stage1 pull."
https://www.facebook.com/cobbtuning/videos/vb.120914804053/10154261777359054/?type=2&theater
DynoJet / 93 Octane / 92F Ambient / 4th gear pulls
Baseline: 304hp / 340tq
Stg1 (Preliminary): 319whp / 364tq
"The IC blocking plate (which COBB removes) is designed to prevent excessive cooling for vehicles in "cold" climates. In these environments LSPI can become an issue and the car will limit power to prevent pre-ignition. We recommend removing this cover for anyone living in environments that are regularly above 50F."
"We've run the car several times back-to-back and have had no reduction in power. Each time, the overboost timer was under the limit."
- Braden Berger (COBB Reverse Engineer / Calibrator)
