Megan Racing Street Coilovers for the Fiesta ST $899 Shipped at Redline360
Trader history for Redline360 (0)
Bay Area
Megan Racing Street Coilovers are the ultimate upgrade to your track or street Fiesta ST. Featuring 32 levels of damper force adjustment, separate spring perch height and shock length adjustment allowing you to retain full suspension stroke and to fine tune your suspension characteristics.
Compression and rebound settings are easily adjusted through a single damper adjustment knob which is built-in at the top of the damper mount for easy access. Adjustments are simple to tune according to your style of driving and desired comfort level whether you are a professional certified mechanic or an automotive enthusiast with amateur mechanical skills. All of our dampers are capable of handling a +2kg/mm or -2kg/mm change in spring rates to further tune your suspension to your desired handling characteristics.
$899 shipped! Order here -> Megan Racing Street Coilovers Ford Fiesta & Fiesta ST (10-14) MR-CDK-FFS10
Height adjustments are made with separate CNC-Machined locking spring perches for accuracy and smooth adjustment with separate damper shock length adjustment to retain full-stroke and allows for precision suspension tuning. The wide range of allowable ride-height adjustment allows for a conservative drop to more aggressive ride heights for an aggressive stance, or to fine tune your suspension for the circuit to gain full potential of your vehicle's handling capabilities.
The quality and durability of the Megan Racing Damper kits are unmatched. Made of extremely durable Steel and featuring springs that are constructed of SAE-9254 Cold-Wound Steel which are then tested over 500,000 times by compression inspection. With deformation less than 5% and high strength sophisticated surface coating, we stand by our product with our strong warranty.
SPECIFICATIONS & FEATURES:
APPLICATION:
Ford Fiesta ST Turbo
SPRING RATES:
F: 5 kg/mm
R: 4 kg/mm
- 32 Levels of Damper Force Adjustment
- Pillow Ball Upper Mounts.
- Rubber Dust Boots
- Adjustable Ride Height
- Aggressive Spring Rates
- Single-Cylinder Design
- Aluminum Brackets
32 Levels of Adjustment:
1-8: Suggested for track use.
9-16: Suggested for mountain/aggressive use.
17-32: Suggested for common street use.
- All kits come with 1 year manufacturer-defect warranty when purchased through an authorized dealer such as Redline360
- All Hardware is Included
iso100
What are those spring rates when converted to ft/lb?
rodmoe
wausau
I'll just leave this here and Also thats a nice price point
kg/mm to lbs/in
16 = 896
15 = 840
14 = 784
13 = 728
12 = 672
11 = 616
10 = 560
9.0 = 504
8.5 = 476
8.0 = 448
7.5 = 420
7.0 = 392
6.5 = 364
6.0 = 336
5.5 = 308
5.0 = 280
4.5 = 252
4.0 = 224
3.0 = 168
2.0 = 112
iso100
61% stiffer up front and 63% stiffer out back. Seems about what the other coil over kits are going with.
