Redline360: Godspeed Coilovers for the Fiesta and Fiesta ST
Trader history for Redline360 (0)
Bay Area
Spring Front Rear
Rate (kg/mm) 5 3
Length (mm) 200 180
I.D. (mm) 62 62
Camber Plate No No
Only $630 shipped! Click here to order: GodSpeed Coilovers Ford Fiesta/Fiesta ST [MonoSS] (2008-2016) MSS0410
Features:
  • Spring rates: Front: 5 kg/mm / Rear: 3 kg/mm
  • 16 precise levels of damper adjustment
  • Koyo Japan 6204z bearing
  • Polyurethane bushing (if applicable)
  • Monotube shock design
  • Anodized shock body
  • Lightweight aluminum lower mount and T7075 forged aluminum / carbon steel brackets
  • 52mm carbon steel shock body with a performance internal piston
  • Independent ride height and spring preload adjustments
  • Race shock oil with a high viscosity index
  • 1 Year Warranty from Date of Purchase
Godspeed Project's MonoSS is our one entity in our family of single-adjustable coilover suspension kits. These coilovers are designed to be a streetable race built coilover at an affordable price. It features a monotube damper that is made out of a carbon seamless steel 52mm tube with a performance internal piston providing maximum damper response. The cold-bent springs are made from high strength SAE9252 steel to optimize the balance between performance and comfort. Using race quality shock oil, Godspeed Project can guarantee exceptional damper performance at any temperature on and off the track. The top of the shock is attached to the car using a high quality top hat that features a high performance Japanese KOYO 6204Z bearing pillow ball mount (when applicable). The bottom shock brackets are made out of a T7075 forged aluminum or carbon steel brackets for lighter weight without sacrificing durability which also includes brake line brackets (when applicable). The MonoSS offers 16 level of damper adjustability which can be set to your preference.
See all Godspeed Coilovers on our site.
danbfree
Tigard, Oregon, USA
So this is the same kit as listed for '07-'14 Mazda2? I know it's the same platform, but no changes for the '14+ FiST huh?
R
Bay Area
Link updated and we also added some more photos to our site of these installed
