I received the duct tubing.
I have designed my next part for this setup, I just need to make the small parts to put together.
I just need two, 6 inch long tubes to start with so I can then build the mounts.
I will going to IMSupply to get some aluminum on Monday.
[MENTION=1391]Siestarider[/MENTION]
I am interested in the fog light vents.
Please provide photos.
I posted some pics from interior side of bumper under Brake Temps thread, and think I have some exterior shots in an exterior mods thread from last year.
Basically, the fog light surround is one piece of ABS. I pulled it loose from tab slots, cut out fake vents, left ribs, attached bug screen to back side, cut round hole through bumper cover behind it, reinstalled, and then riveted round hose fitting to inside of bumper facia over the hole. Manometer tests indicate good pressure drop available.
When the cooling shrouds come in from CMbuildz I will start a new thread and shoot better pics, run temp tests again and see what data indicate. I plan to keep using stock calipers, would like to use 2 piece rotors just to save a little unsprung weight if someone will figure out which parts work with stock calipers and brackets.
