X-57 Series Turbocharger Upgrade (Ultimate bolt on turbo upgrade) $1659.99
Trader history for pwnall1337 (0)
pwnall1337
San Antonio
Presenting the Ultimate Bolt on Direct fit turbo upgrade for your 2013-2019 USDM Ford Fiesta ST! Built and designed from the ground up in the UK with a proprietary bespoke compressor and turbine housing no other turbo upgrade comes close. Pwnall Performance is the only USA authorized dealer for the X-57 turbos and the number one choice for tuning your X-57 series turbocharger.
To build the perfect turbocharger you must understand the desires of the customer and understand the dynamics of the engine itself.
The 1.6 EcoBoost motor has no better home than Pumaspeed, with 20+ years experience, race engines being built every week to power levels of over 450bhp you couldn't be in better hands.
The X-57 series of turbochargers have been designed from the ground up with a no compromise attitude. They feature the very latest spec genuine K04 / K16 Motorsport internals and state of the art billet 7 blade CNC compressor wheels. The turbos have been testing on road and track since late 2018 and have easily proven themselves durable and without compromise on power, reliability and response.
For the very best in performance for the ST180 1.6 EcoBoost there is only one number you need to remember, 57.
Features:
  • Direct Bolt on
  • Up to 450 Capable ( Engine, Hardware and Fueling Dependent )
  • Designed, Cast and Fully Built in the U.K.
  • 7 Blade Extended Tip Billet CNC Compressor Wheel
  • Motorsport Heavy Duty Thrust Bearing Pack Assembly
  • Includes all Required Fitting to Enable direct bolt on
  • No Exchange Unit Required
  • 27~ psi @3300 rpm with 14.5 psi by 2400 rpm
  • Highest hp turbo for it's spool up on the market!
More info:
http://pwnallperformance.com/Pumaspeed-X-57-Series-Turbo-Upgrade-450-HP-capable_p_225.html
